Johnelove
Oct 05, 2017Follower
APN settings for NYC based T-Mobile
Hi, I have the LB1120 LTE router. I 'am using a T-Mobile sim card and I am in the NYC area. Speed tests have been erratic. Mostly I get 56k speeds. However occasionally when I reset the router I will ...
Micamelus
Oct 08, 2017Aspirant
I just used IP4 on both. Or IPv6 on roaming.
See if that will help you out.
They are the settings I have on my phone, as well. It should work for you without a hitch.
Let me know!
Let me know!
