santini
Oct 29, 2017Follower
AT COMMAND PASSWORD for Optus AC800S
Hi there, I'm trying to gain access to my Optus AC800S https://www.netgear.com/support/product/AC800S_Optus.aspx via the telnet , but I need the password to run the protected commands. AT!ENTERCND...
JamesGL
Nov 10, 2017NETGEAR Employee Retired
Hi santini,
You have to check with Optus as this is an ISP provided unit.
andrespilak
May 05, 2018Initiate
I hope someone will find out , how to set band locking / frequency selection in netgear optus ac800s , i recently purchased purchased ac800s and it automatically connects to band1 ( congested slower speedtest in my area but have a strong signal / full bar) , i want to choose band 3 or band 40 even if it has a 3-4 bar signal - the speedtest is faster 10x than the band 1 here in my area (based on my huawei b315-936 with band selection), its just a waste of my money that i coudnt use the full capability of the modem aircard if i coudnt choose the band that i want.
