cmyorke1
Jan 15, 2020Aspirant
AT&T MR1100 Ethernet Port inop
I am using an AT&T branded Nighthawk MR1100. It recently updated firmware to 12.05.05.12. Since this update I am not able to connect to the ehternet port with any devices. I was using it with a Links...
JohnPeng
Jan 16, 2020NETGEAR Expert
We are actively working on this issue.
Sorry for the inconvenience and thanks for your patience.
Regards
- JohnPengJan 16, 2020NETGEAR Expert
Could you please advise when the issue happens on ethernet port, do you still can connect to WiFi and browse the internet?
Thanks
- cmyorke1Jan 16, 2020Aspirant
Yes i am still able to connect to WIFI and browse. Once connected to ethernet there is no internet available through the port.
Did you also connect your MR1100 to your computer using USB cable at the same time you were using ethernet port?
