cmyorke1
Jan 15, 2020Aspirant
AT&T MR1100 Ethernet Port inop
I am using an AT&T branded Nighthawk MR1100. It recently updated firmware to 12.05.05.12. Since this update I am not able to connect to the ehternet port with any devices. I was using it with a Links...
lukelu
Sep 23, 2020Aspirant
Got the same issue (We are using ATT bussiness plan). Wifi works but ethernet doesn't.
ar_james
Oct 20, 2020Aspirant
Same 'No Ethernet' issue on my MR1100 M1 router. I have a trouble ticket open. I have the latest ATT provided firmware 12.05.05.14. I saw some threads where this version should have corrected the issue. My ethernet port is broken. The wifi and the USB port will still connect. I have a USB 3.0 to Ethernet adapter that came with my laptop plugged into the usb. That works for now, but I think there is a speed decrease from what ethernet would be.
- GJHowellDec 13, 2020AspirantAnyone found a fix. This is the second I've had to do this.
