Chezehead
Feb 25, 2021Follower
AT&T MR1100 No WIFI
I have a MR1100-2A1NAS that I cant enable WIFI. It has the latest firmware in it. Even after a hard factory reset with the button or in the software WIFI should be enabled by default. The only ...
vip991988
Jun 08, 2021Aspirant
Noone to support ^^ my issue is can't connect any devices to setup MR1 1100 Y_Y
michaelkenward
Jun 09, 2021Guru - Experienced User
We don't know enough about what you are doing and where it goes wrong. So it is hard to respond. Unfortunately, "still no WIFI" could mean several things.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual WiFi Settings.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
