Aidan_Kelley
Oct 11, 2020Follower
at&t net gear nighthawk
The battery swelled up a lot and might explode soo
Oct 11, 2020Guru - Experienced User
If you're within your warranty period, start an rma process.
click on mynetgear at the top, register an account and then device. from there start the rma .
If you're not, remove that sh*t and order a new battery. lithium does go bad. safely dispose/recycle the old one.
