pkdstuff
Jan 16, 2018Tutor
AT&T Nighthawk LTE Mobile Hotspot Router MR1100
Is it bad for the device to leave it usb connected and charging the battery? After my battery became fully charged the display on the router said to disconnect the charging cord.
roxyz
Mar 10, 2018Aspirant
I can address this. I have the same question, because I use the hotspot as my only source of internet (I live in a rural area where there is no viable internet service). I have been plugging it in every morning and have to remember to unplug it every night and plug it back in the next morning. I would also prefer to just leave it plugged in, as I don't need to move it. THAT is the problem with unplugging it.
JSchnee21
Mar 16, 2018Virtuoso
Hi roxyz,
There are many MR1100 users here on this forum that have had very good success running the hotspot with the battery removed. Be sure to get a QC2 or QC3 capable charger from a reputable company like Anker.
Many have found that the oem supplied charger is inadequate to run without the battery and trying to do so can result in crashed and reboots of the hotspot. But many on this board using a QC2 or QC3 charger (plugged into the USBC connector) have been running rock solid for months without a battery.
The other issue some have experienced and/or postulated may be a concern is overheating under high load which can also results in crashes and reboots. Though I'm not sure if this cause and effect relationship is as clear cut. Some use fans and or heatsinks to cool the device and leave the back open and elevated after removing the battery.
Some folks also lower the display brightness, though I don't really see how this would really help much as the display is only on for 30s or a minute typically when you push the button.
