tyreeburnett
Aug 16, 2019Follower
AT&T nighthawk m1 paired with Netgear AC1900?
Okay so I have the ATT nighthawk m1 and have a netgear ac1900 router coming in the mail. I'm writing this so when it comes in the mail, I'm not confused on how to pair the two. So from my understanding, on the nighthawk m1 I have to turn on IP PASSTHROUGH, enable DHCP, & disable ETERNET STANDBY? ( I saw this guy do it on a youtube video )
and then login into the NETGEAR router and change the IP address to 192.168.0.1 and I should be good to go?
I just want to make sure this sounds right to a techie on here. any helps is appreciated :)
Hi tyreeburnett
Welcome to NETGEAR Community!
Enable IP Passthrough Mode on the MR1100 is 1 of your option. Here's your reference:
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf [page 53.-54]
Nothing needs to be done on AC1900 router side.
Blanca
Community Team
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi tyreeburnett
Blanca
Community Team
