Pontifier
May 08, 2024Aspirant
ATT Nighthawk M6 Pro Ethernet always isolated?
I am trying to make some services available through the wired network port, but am unable to access any wired devices while wirelessly connected to the M6. Isolation mode is turned off in the web GUI.
Any ideas? Wireless devices can see each other, but not wired devices, and vice versa. Everything is able to see the outside network.
1 Reply
- robert1997bAspirant
Ensure that AP Isolation is indeed turned off for both the 2.4GHz and 5GHz bands if your router supports dual-band operation. Also, verify that the DHCP settings are consistent across both wired and wireless connections. Use network tools to scan your network from both wired and wireless devices to see if they can detect each other. Tools like Wireshark can help you diagnose if the packets are reaching the devices or being blocked.
