Willgregg73
Dec 19, 2022Guide
AT&T Nighthawk M6 Pro wifi range (or lack of)
Just got the M6 Pro from AT&T. I've got steady 3 to 4 bars of signal. Speed is about 130mbps if I'm right next to the device. If I walk 10 feet away, even line of sight, it drops to low 20mbps. If I s...
Hotspot40324
Dec 22, 2022Guide
I have the Dish/Project Genesis version -- MR6400. To overcome the WiFi range issue I added a Netgear AC750 Dual Band WiFi Range Extender (EX2800) & set the hotspot WiFi to 5GHz and the extender-to-device WiFi to 2.4GHz ("FastLane"). I'm happy with the results so far.
- Willgregg73Dec 22, 2022GuideMy netgear AC3700 (I think) plug-in extenders don't seem to want to connect at all. They detect the M6, and looks good all thru setup, but then won't connect. I'm hoping to get something that is more plug & play
