Willgregg73
Dec 20, 2022Guide
AT&T Nighthawk M6 Pro wifi range (or lack of)
Just got the M6 Pro from AT&T. I've got steady 3 to 4 bars of signal. Speed is about 130mbps if I'm right next to the device. If I walk 10 feet away, even line of sight, it drops to low 20mbps. If I s...
YDB1
Feb 24, 2023Tutor
I have a couple 2.4 and 5 g routers, do I plug into the LAN port on the M6 then go to the router?
Willgregg73
Feb 24, 2023Guide
Yes that's what I did, from M6 LAN port to router. The reason I bought my particular TP Link router was because of its advertised range. I did not want to deal with extenders or a mesh system. So far, so good👍
