vartanarsen
Apr 08, 2019Follower
ATT Nighthawk MR1100 stuck on boot logo and boot fails
hi all, this started happening tonight. I tried everything, the only option is to take out battery and put it back, then it goes back to get stuck on the logo and then stops trying to boot. I dont ...
- Apr 16, 2019
Hi vartanarsen
Welcome to NETGEAR Community!
I suggest to reboot the unit without the sim card. If the device completely boot up then perform a factory reset by following the steps provided by plemans. Once done, insert the sim card again and check how it goes.
Blanca
Community Team
Blanca_O
Apr 16, 2019NETGEAR Employee Retired
Hi vartanarsen
Blanca
Community Team
Blanca_O
Apr 21, 2019NETGEAR Employee Retired
Hi vartanarsen,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
