LeifA
Jul 24, 2020Apprentice
Auto restart M1?
Hi! Is there any way to get an automatic restart of the M1 router regulary? It seems to be needing that once a while to regain speed. I am using it 24/7. Regards Leif
LeifA
Jul 26, 2020Apprentice
Ok, thanks!
Could not find any such script here. Was if for M1 specifically or general?
Does it change any settings in the M1 or does it need to run from a PC? I need something that is automatic in the modem itself, seldom use my laptop here and if so I can restart manually.
Regards
Leif
icaruspony
Jul 26, 2020Luminary
Here it is:
You can run it as a Python script on a machine that is always on. Or better yet, you can run it on a router that connects to your MR1100.
- LeifAJul 26, 2020Apprentice
Thanks!
Unfortunately that's to complicatef for me, know nothing about python.
If the function isn't included in this router I'll live with that. My earlier Teltonika modem had a function to schedule restarts. The M1 is much faster though.
Regards
- icarusponyJul 26, 2020LuminaryYou could use a timer plug or smart plug, with no battery in the hotspot.
Thanks, that's a great idea!
Leif
