AileenCS
Jan 14, 2023Follower
AX3600 MR6110 5G cannot connect Uniden solo+ security camera
There was an earlier post (2019!) with same problem. I am trying to connect a Uniden Guardian solo+ security system. Phone App displays 'Connection to router succeeded' then 'Connection to the router failed'. Maybe Uniden device not compatible with 5G?
1 Reply
- KitsapMaster
AileenCS wrote:There was an earlier post (2019!) with same problem. I am trying to connect a Uniden Guardian solo+ security system. Phone App displays 'Connection to router succeeded' then 'Connection to the router failed'. Maybe Uniden device not compatible with 5G?
You will get more responses and better answers if you post in the community specifically set up for your type of hardware.
Try here: https://community.netgear.com/t5/Cell-Service-Mobile-Hotspot/bd-p/aircard
Most likely a moderator will move your post.
