Chuck1j
Jan 15, 2021Follower
Bad default password LB1120
I have an LB 1120 Wireless Router I purchased last March but never hooked up due to Covid problems. No Netgear won't allow me support.
The Default Password does not work. I have tried all suggested fixes none of which has worked. A search of the community only shows the same defective fixes over and over.
Is there any fix for this or is the modem just a BRICK?????
Thanks
Chuck
1 Reply
It is actually a modem. The manual tells you how to connect it to a router:
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Connect a Computer, Switch, Hub, Router, or WiFi Router to the Modem.
Is that the login password?
What are you doing when it does not work? Dies it throw up any error messages?
Tell us what they were, so that we know that you are looking in the right place. As it is we have no idea what you have done.
