Schutti
Jul 11, 2018Apprentice
Band 28 at the M1 Netgear MR1100 EUS
does the M1 support the entire Band 28 in the European version (EUS) as well?
There is a device from another manufacturer which supports the volume 28 only to the extent of the European releases, 2...
Schutti
Jul 12, 2018Apprentice
I cannot post new Text here.
Schutti
Jul 13, 2018Apprentice
I want to post a reply to this Topic but the Software is deleting it automatically.
- SchuttiJul 15, 2018Apprentice
The australien Version ist supporting the Band 28 (700 MHz)
The EUS Version too.
But in Europe only 2x30 MHz can be used because The band 28 overlaps with band 20.
One Manufacturer built a Router that uses only the european Band 28 Mapping, not the whole Band (2x45 MHz in Asia or AUS).
Is the Band 28 support with the whole Band in the EUS M1 or only the european 2x30 MHz?
