SharonWillis
Mar 24, 2022Initiate
Battery low nighthawk m2
I forgot to charge my new Nighthawk M2 mobile router and The battery is extremely low and modem not working. I have taken the battery out and back in and it comes on for a minute then off again. It th...
- Mar 24, 2022
Glad its charging!
You might mark its solved so others aren't trying to fix it when you've got it working 🙂
Mar 24, 2022Guru - Experienced User
have you tried charging it with the router off?
Or tried a different charger? Maybe the one you're using isn't supplying enough power to charge it from zero and run it at the same time
SharonWillis
Thank you for replying. It has finally moved off of 1%, now slowly charging, now on 7%. Must make sure I keep it charged.
- plemansMar 24, 2022Guru - Experienced User
Glad its charging!
