SharonWillis
Mar 24, 2022Initiate
Battery low nighthawk m2
I forgot to charge my new Nighthawk M2 mobile router and The battery is extremely low and modem not working. I have taken the battery out and back in and it comes on for a minute then off again. It th...
- Mar 24, 2022
Glad its charging!
You might mark its solved so others aren't trying to fix it when you've got it working 🙂
SharonWillis
Thank you for replying. It has finally moved off of 1%, now slowly charging, now on 7%. Must make sure I keep it charged.
Mar 24, 2022Guru - Experienced User
Glad its charging!
