Wywurri
May 01, 2020Aspirant
Battery not charging
New router purchased mid April. Using via mains power. Used battery only once. Battery not re-charging all connections as per user manual.
JohnPeng
May 06, 2020NETGEAR Expert
Please advise the SKU name of your device. When you try to charge the device, what shows in the LCD UI?
Thanks
- WywurriMay 06, 2020Aspirant
Txs for your reply John Peng, the device has righted itself - battery now accepting charge without intervention. Not sure what the original problem was
- Blanca_OMay 07, 2020NETGEAR Employee Retired
Hi Wywurri
This link may help:
What do I do if my Netgear Mobile Hotspot/Router is not charging its battery to 100 percent?
Blanca
Community Team
