Wywurri
May 01, 2020Aspirant
Battery not charging
New router purchased mid April. Using via mains power. Used battery only once. Battery not re-charging all connections as per user manual.
Wywurri
May 06, 2020Aspirant
Txs for your reply John Peng, the device has righted itself - battery now accepting charge without intervention. Not sure what the original problem was
Blanca_O
May 07, 2020NETGEAR Employee Retired
Hi Wywurri
This link may help:
What do I do if my Netgear Mobile Hotspot/Router is not charging its battery to 100 percent?
Blanca
Community Team
