CRS50
Mar 28, 2018Follower
Battery Required? in remote location with AC power - NETGEAR Fuse Mobile Hotspot AC779S
I am using my NETGEAR Fuse to turn on an engine heater at a remote site via a smart switch on the average of twice a month during the winter months. I am concerned about starting a fire, not by the s...
JSchnee21
Mar 28, 2018Virtuoso
Hi CRS50,
I know the new Nighthawk MR1100 will if you upgrade the charger to a QC2 or QC3 charger and use USBC. Sorry I don't know for the Fuse. I know my old hotspot from ZTE (and many others) will not operate without a battery.
Try and see. If it turns on, stays on, and continues to work underload (ex Fast.net, Okla, etc.) it should be fine. My ZTE would not even turn on if no battery was installled.
-Jonathan
