Baco
Dec 28, 2021Aspirant
Best Configuration for my home.
Ciao, I would like to understand what is the best configuration for my home. My home has 3 floors (about 65 squared meters each) and the modem/router (Tim Hub) is placed in the central floor. From...
Baco
dear michaelkenward ,
I have a XDSL connection (over Telephone line).
Thanks for your suggestions but, what I'm not able to understand, is if I can exploit, for example with Orbi, ethernet cables to link the router with the extenders.
Is it possible?
I think that this type of connection should be better than wireless connection, isn't it?
Thanks in advance.
Samuele
michaelkenward
Dec 29, 2021Guru - Experienced User
Is it possible?
Correct.
If you have Ethernet throughout the place, then you should be able to connect a router to the network and then attach wifi "repeaters" around the place.
This is known as "wired backhaul". The Orbi technology can certainly handle this.
That would actually be faster and more reliable then having wifi links between the router and the satellites.
