erikjond's avatar
erikjond
Follower
Jun 05, 2018
Best mobile broadband router
Will one of you mobile broadband experts just simply tell me which mobile broadband router will give me the best continual speeds, something that will handle a small to medium business wireless load, something that has decent security features, and it MUST be wireless - I have this Netgear M1100 and it has been broke down more than it has worked. PLEASE HELP ASAP!!!!!!!!!!
1 Reply
  • johngm's avatar
    johngm
    NETGEAR Employee Retired
    I am sorry to hear about your unsatisfactory experience with the M1100.   Not sure what "broke down" means but I have had good experience with our line of mobile hotspots.   ATT supports the product you are referring to so if the performance is unsatisfactory you should reach out to them and have them sort it out.
    You asked for input so I will pass along a few comments.   If you are trying to run a continuous business internet (many clients) you might want to consider an LTE bridge like
    LB2120 (dual Ethernet with failover), LB1120 (LTE modem only), LB1121(LTE modem with POE) these are all solutions for ATT in the US.   This will require a separate access point or WiFi router to support your wireless clients.
    John
