farukhcasy2
Jul 24, 2020Follower
Best mobile wifi router for car.
Hi, Could you recommend a mobile wifi router (with LTE support) which could be used in car? I considered Huawei E5573CS-322 but I'm not sure if leaving a device with a bettery inside of a car is ...
icaruspony
Jul 25, 2020Luminary
Best? Nighthawk MR1100. You can remove its battery and power with USB.
