lucassilva11
Aug 16, 2026Aspirant
Best NETGEAR Mobile Hotspot Settings for Gaming?
I've been wondering how much difference the configuration of a mobile hotspot makes when using it for gaming. Download speed seems less important than stable latency and avoiding sudden connection...
NairB
Aug 22, 2026Star
Hi lucassilva11. Sorry for the double post. No edit function on this forum. I use a Netgear M6 Pro router and sits in direct line of site to my cell tower approx 135m or 443 feet away from cell tower. I have the battery removed and powered by the Netgear supplied power supply and set to Maximum Performance. I also utilise the M6 Pro Ethernet port via a 2.5G switch hard wired to PC when Gaming. I can get 18ms latency and 35 jitter not bad at all for a Mobile Router solution.
