Jabz
Mar 11, 2017Follower
Bigpond Aircard 790S won't connect at 8011.ac
I recently bought a used Aircard router AC790S and getting problem with the charging. It will not charge sometimes through USB cable. I tried in mobile adapter + usb cable and computer + USB cable as well.
I dont have the box or the original charger. Please tell me a solution for this.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Jabz
What is the volts and amps of the charger that you are trying to use?
DarrenM
