intoxicthreat
Feb 20, 2020Follower
broadband disconnected
Today I woke up to my Broadband disconnected again. Some of the issues reported already never really gave a clear answer on how to fix this issues. If T-mobile is really blocking the connection to my...
JohnPeng
Feb 21, 2020NETGEAR Expert
Most likely, the device was blocked by T-Mobile when you use the T-Mobile SIM.
Can you try the SIM card work on your phone?
Thanks
melwiththecell
Feb 22, 2020Guide
Would you advise downgrading the Firmware by USB connection? Or do you have some sort of timeline on a patch?
Thanks!
- WebbwulfFeb 22, 2020TutorIt's netgear side of things it the patch
- melwiththecellFeb 22, 2020Guide
I agree. Had the same issue with an ATT sim, so it's definitely a Netgear issue. I have JohnPeng responding to my messages, so hopefully it will get resolved soon.
