intoxicthreat
Feb 20, 2020Follower
broadband disconnected
 Today I woke up to my Broadband disconnected again. Some of the issues reported already never really gave a clear answer on how to fix this issues. If T-mobile is really blocking the connection to my...
melwiththecell
Feb 22, 2020Guide
Would you advise downgrading the Firmware by USB connection? Or do you have some sort of timeline on a patch?
Thanks!
Webbwulf
Feb 22, 2020Tutor
It's netgear side of things it the patch
- melwiththecellFeb 23, 2020GuideI agree. Had the same issue with an ATT sim, so it's definitely a Netgear issue. I have JohnPeng responding to my messages, so hopefully it will get resolved soon.
