intoxicthreat
Feb 20, 2020Follower
broadband disconnected
Today I woke up to my Broadband disconnected again. Some of the issues reported already never really gave a clear answer on how to fix this issues. If T-mobile is really blocking the connection to my...
Bornmega
Feb 24, 2020Aspirant
I'm also in the same boat and a Tmobile sim inside. I've spoken to tmobile customer service and was told everything on their checks out fine. I went in and got a sim change in case it was the sim card, still getting the same problem. I've tried the new sim in another device and works perfectly fine. I went to an att retail store an borrowed an active sim and it connected, but I couldn't push a firmware update.
melwiththecell
Feb 24, 2020Guide
I did the firmware push through the GUI with my ATT sim. However, Tmobile gave us a new APN to connect to, but you should ask your ISP to work with Tmobile for that, as it could be different for each reseller.
