intoxicthreat
Feb 20, 2020Follower
broadband disconnected
Today I woke up to my Broadband disconnected again. Some of the issues reported already never really gave a clear answer on how to fix this issues. If T-mobile is really blocking the connection to my...
thegalline
Feb 28, 2020Tutor
John
received your PM. I looked at the file and there seems to be a lot of personal and proprietary data in it.
I have a call into T mobile. I want them to tell me it is ok and safe for me to share.
thank you for understanding.
thegalline
Feb 29, 2020Tutor
John
Sorry, but T mobile recommended that I not share that file.
I talked with one of the Sr tech reps and he is going to escalate the problem report.
If you have not done so I would suggest you contact T mobile to get this fixed and not depend on your customers.
- thegallineMar 04, 2020Tutor
John
Where do we stand with this problem?
Has Netgear made any progress toward a solution? When can we expect to get a fix?
It has been 2 weeks since my hotspot stopped working.
- JohnPengMar 05, 2020NETGEAR Expert
thegalline wrote:
John
Please try the following:
1. Log in to WebUI
2. Manully create an APN use "b2b.static" as APN name with IPv4 chosen for both PDP and PDP Roaming
3. Check the radio button in front of the newly created APN to set it as default.
4. Mak sure Data checkbox is checked.
Let me know whether this works or not.
Thanks
- thegallineMar 06, 2020Tutor
John
I do not know what WebUI is but I was able to create the new APN through the Netgear mobile app. I selected it and rebooted the device. No change. Will not connect.
- thegallineMar 11, 2020Tutor
Problem found.
My hotspot has been running on the T Mobile system as a tablet. (T Mobile set it up when I bought it)
With the firmware update, the system realized it was a hotspot instead of a tablet. The T Mobile engineer I was working with changed my line to a hotspot data line and the device starting communicating right away.
If your hotspot is still not working you are on a tablet or phone type line and you will have to change your line type and T Mobile plan (at a lot more money).
Many thanks to John Peng for his assistance.
- atg321Apr 12, 2020Tutor
I have been having the same "Mobile Broadband Disconnected" problem for the past several months. NETGEAR sent me another MR1100 and I am having the same problem. I have T-mobile. I have a NETGEAR LB1120 working with no problems. NETGEAR blames T-mobile, T-mobile blames NETGEAR. Consumers are getting caught in the middle. EVERYTHING started after a NETGEAR firmware update. IS NETGEAR GOING TO FIX THIS ISSUE? We are talking $350 down the drain. Return my money if all I am going to have is a $350 paper weight..........
- JohnPengApr 12, 2020NETGEAR Expert
For T-Mobile customer, please contact T-mobile to upgrage your plan to Hotspot plan in order to use with MR1100. T-Mobile treated MR1100 and LB1120 as different device categories. That is why the same SIM card can work on LB1120, but not on MR1100.
Thanks
Well John, this device was working just fine until NETGEAR updated their firmware a few months ago. Why is the fault been placed on T-mobile then? When I bought this device it was advertised to be unlocked and capable of working with T-mobile. It did just that for lesss than 5 months. $350 for only 5 months of service is what I call A RIP OFF!!!!
As we found out that T-Mobile limted the Tablet plan to work with MR1100. This is out of our control. One of customers did help to try downgrading to an older release and confirmed that after FW downgrade, the data connection didn't work either. So the issue was not really caused by FW upgrade.
Thanks
Well, as many other customers with the MR1100 are commenting on the internet, it was a big coincidence that all this happened RIGHT AFTER the NETGEAR firmware update. I guess we are out of luck and $350 and NETGEAR gets to keep our $$$ and just say it's not your fault. Sorry to sound so bitter but I don't believe in such coincidences. $350 is a lot of money. Have a nice day!!
- JohnPengApr 12, 2020NETGEAR ExpertThe device still works with T-Mobile, but you need to get the right data plan.
Thanks - JoeNDiverMay 21, 2020AspirantJohn, I have two TMi lines, one static IP one not, using different APN, b2b.static, and fast.tmobile.com. I have two mobile routers, this M1, and a MoFi4500-4GXeLTE V2. For service, since where we live there are no broadband providers, we have to rely on unlimited data from Tmo reseller, on Tmo's grandfathered unlimited plans.
Originally I had non-static sim card in M1. Tmo blocked the sim in February from using M1. I figured that out by swapping Sims and settings. And both were working for a while, since B2B.static APN worked on M1. However, as of a few days ago, Tmo also blocked my B2B.static sim card from using M1. And now I am down to one mobile router, and M1 is blocked from using both Sims.
So why is it that another true mobile routers (with external antennas and wall wart power plug, not to mention industrial chassis) can work with Tmo, and M1 cannot? Why when there was talk of certifying M1 to work on Tmo to qork, it was ignored? Surely if ruralinternethq.com can get certification from Tmo for the routers they sell, you can too?
As a previous poster mentioned, this is creating a very expensive paperweight, and is damaging to the Netgear brand, showing the Netgear is not even as serious a player in Mobile Internet arena as much smaller brands as MoFi. As 5G is coming around the corner and everything will be mobile internet enabled, surely Netgear will be poised to lose that emerging market share if cannot play nice with the carriers like others. - jimmyoakesJul 15, 2020Initiate
Had one of these previously on ATT (unlocked) that I haven't used for months.Just decided to use it and all different sims including ATT give the same issue.
Tried the APN trick with no luck.
Here are the different set of active sims I tried -
ATT (for MiFi)
T-Mobile (for MiFi)
Google Fi (data sim)
O2 (UK data sim)
This is simply crazy. This is definitely not an issue with the providers as all these sims work fine with other devices from Huawei etc.
Any suggestions?
- JohnPengJul 15, 2020NETGEAR Expert
ATT (for MiFi)
T-Mobile (for MiFi)
O2 (UK data sim)
Any suggestions?
Please help to capture model.json log.
1. Open Browser and go to 192.168.1.1
2. Log in as admin. You can find the admin password on the product label under the battery
3. In anothe tab, open: http://192.168.1.1/model.json
4. Save the texts in a file and send a private message to me.
Please send the file for each SIM card.
Thanks
