Inglorious10Tv's avatar
Apr 22, 2020
Buying a night hawk m1
So I’m looking to buy a m1 and I was online and on amazon they have them for 400 but here they are around 300. Does anyone know if either one of them come with a plan or are they just the router. I’m ...
  • Lexsteel's avatar
    Lexsteel
    Apr 24, 2020
    You will still need a provider, but the device will not be locked to one provider (unlocked)
    Then you can get the best provider in you country.
    I bought my device for £140 , then I got a data plan for £20 per month
