chrissy68
Mar 21, 2018Aspirant
Cable for Unite Explore
I have lost the battery charging cable for my Unite Explore 815S and I cannot find one online anywhere. Can anyone help me find where I can buy one? I need it ASAP because it's for my work and I am a...
JasonN
Mar 22, 2018NETGEAR Employee Retired
Hi chrissy68,
Are you just asking about the cable? If so it is a USB to Micro USB cable that you need.
Please let me know if this helped you. :]
- Jason N
- chrissy68Mar 23, 2018Aspirant
Thanks for replying! The cable that I'm looking for isn't your typical USB connection. The one that I need connects to this opening. The other end will be the USB connection.
- JasonNMar 23, 2018NETGEAR Employee Retired
Hi chrissy68,
Thank you for your response. When you are saying "The one that I need connects to this opening", which opening are you talking about?
Please let me know. :]
- Jason N
The connection in the bottom middle of the the MIFI that has the arrow pointing to it in the attached picture (with the bent area in the middle of the connection). Thanks!
