DSchofield
Mar 20, 2020Aspirant
Can’t find the password on the router label
What is the network security key? Where do I find it? On my router label?
- Mar 20, 2020I meant to ask about the PIN number from the router label. Where do I find it?
DSchofield
Blanca_O
Mar 22, 2020NETGEAR Employee Retired
Hi DSchofield
You can also connect to the WiFi network by entering the network security key. Kindly click "Connect using a security key instead" and enter the WiFi network password.
Blanca
Community Team
