Kevin234
Apr 18, 2021Aspirant
Can anyone help me with my home networking issue?
Straight to the point - my router is downstairs and my computer upstairs. No ethernet jacks anywhere in the house and impossible to install them since we are renting. My room is re...
- May 11, 2021
Thank you all for your responses and help.
https://19216881.org/ https://1921681001.link/ https://19216801.digital/
ArodiD
Apr 18, 2021NETGEAR Expert
Hi Kevin234 ,
I have had similar issues in the past. I would recommend something like an Orbi or a Nighthawk Mesh system. Plug your PC into one of the ethernet ports of a satellite and the router can be plugged into your existing NBN modem. The WiFi chipset on the satellite will outperform your PC's WiFi adapter which will give you a more stable connection. In my case I did not see a degradation in speeds connecting to router or satellite.
Arodi
