MikeyrInScott
Feb 18, 2022Initiate
Can I connect my Orbi LBR20 to my TP-Link AX1800 WiFi router and repeaters?
I already have a TP-Link AX1800 WiFi router and some TP-Link repeaters/extenders. I am upgrading from a CAT 4 4G LTE router to an Orbi LBR20 4G LTE CAT 18 router. Can I run an ethernet cable between ...
- Feb 19, 2022
I just mean that if the orbi is broadcasting on channel 1 for 2.4ghz and 36 for the 5ghz, to have the tp-link on different wireless channels like channel 11 for 2.4ghz etc. Helps prevent interference
Feb 18, 2022Guru - Experienced User
You can but you'd want the tp-link in access point mode to prevent a double nat.
Also make sure to have the wireless channels from the orbi to the tp-link on different channels to prevent interference
- MikeyrInScottFeb 19, 2022Initiate
plemans wrote:You can but you'd want the tp-link in access point mode to prevent a double nat.
I understand about the TP-Link router in access point mode. I'm not completely sure what you meant by "...make sure to have the wireless channels from the orbi to the tp-link on different channels to prevent interference" Should I have mentioned that the connection from my Orbi LBR20 LTE router to my TP-Link AX1800 WiFi router will be by ethernet?
- plemansFeb 19, 2022Guru - Experienced User
