MikeyrInScott's avatar
Feb 18, 2022
Can I connect my Orbi LBR20 to my TP-Link AX1800 WiFi router and repeaters?
I already have a TP-Link AX1800 WiFi router and some TP-Link repeaters/extenders. I am upgrading from a CAT 4 4G LTE router to an Orbi LBR20 4G LTE CAT 18 router. Can I run an ethernet cable between ...
  • plemans's avatar
    Feb 19, 2022
    I just mean that if the orbi is broadcasting on channel 1 for 2.4ghz and 36 for the 5ghz, to have the tp-link on different wireless channels like channel 11 for 2.4ghz etc. Helps prevent interference
