mchotti
Jan 24, 2020Follower
Can I connect the MR1100 to an existing Wifi AccessPoint?
Hello, I would like to use the MR1100 as a mobile router for an application where 20 devices are connected to it. On the way you can use LTE, but in the office I would like to connect the MR1100 to an existing network, because here in the office no LTE works.
Is it possible to connect the MR11000 to an existing network via WLAN to connect all connected devices over it?
1 Reply
- JohnPengNETGEAR Expert
Yes. You can enable wifi or ethernet offloading in the office for the purpose. But I think it is better to use ethernet offloading since the connection is more reliable than WiFi offloading.
You can refer to the user manuel online for the detail setups. If you have further questions, please let me know.
Thanks
