flipperdop
Apr 06, 2023Aspirant
Can i flip the screen on a NETGEAR Nighthawk 5G Router MR5200
Hi Group I have a NETGEAR Nighthawk 5G Router MR5200 but where the cables come intot he back of the unit and i look at it rom the front of my desk the screen is upside down... is there a way in th...
michaelkenward
Apr 06, 2023Guru - Experienced User
flipperdop wrote:
Hi Group
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
flipperdop
Hi Michael
thankyou for your reply, i did loo and google around a bit but can't find any information on weather this is possible.
Thankyou for asking for the message can be moved to a better forum, hopfully somone might be able to help.
A
- michaelkenwardApr 06, 2023Guru - Experienced User
Not your fault. This place is a mess. It is easy to get lost.
