Justyw
May 11, 2017Tutor
Can I hide my password on a Nighthawk M1 router?
Hi I've just set up a Nighthawk M1 router for my parents and was wondering if there is any way to hide the password that appears on the digital display to stop grandkids being able to log onto th...
Souvorkin
Sep 30, 2017Tutor
Why yes, yes you can, here's how:
Log into you router's setup menu (http://m.home/), log in, Go To: Setup, then Wireless, then scroll down to Global Wireless Setting and UN-check the "Display Info on LCD".
Done.
Justyw
Sep 30, 2017Tutor
Thank you so much, I will try that when I return home from holidays, much appreciated! Cheers.
