dwkns's avatar
dwkns
Can I hide my password on a Nighthawk M6
The password show on the homescreen of my router. How do I hide it? Thanks   -dwkns
  • dwkns's avatar
    May 16, 2023
    Answering my own question incase anyone else comes across this.
    On firmware NTGX65_12.01.05.00, you can show/hide the Display Info on the LCD by going to:
    Settings > WiFi Band > more** > Global Settings > Display Info on LCD
    **more is in tiny type at the bottom of the panel after the buttons to choose which band you want the WiFi on.
