dwkns
May 15, 2023Aspirant
Can I hide my password on a Nighthawk M6
The password show on the homescreen of my router. How do I hide it? Thanks -dwkns
- May 16, 2023
Answering my own question incase anyone else comes across this.
On firmware NTGX65_12.01.05.00, you can show/hide the Display Info on the LCD by going to:
Settings > WiFi Band > more** > Global Settings > Display Info on LCD
**more is in tiny type at the bottom of the panel after the buttons to choose which band you want the WiFi on.
W1lliam
May 15, 2023Virtuoso
Login to the device bia Web Browser, goto Setup->Wireless, unclick "Display Info on LCD" and the password, also SSID, will be shown as "*" unless you touched it from LCD panel.
dwkns
May 16, 2023Aspirant
There is no Wireless option!
I've looked through all the settings and can't see "Display Info on LCD" anywhere.
I've updated to the latest firmware (see attached).
Any other ideas?
