gflynt
Dec 27, 2017Aspirant
Can I leave plugged in and on all the time??
ok, I read through a LOT of post and cannot seem to get a consensus on this. I've tried others brand like Franklin but usually quits in two or three days. Tried everything including taking out batte...
mdgm-ntgr
Dec 27, 2017NETGEAR Employee Retired
If you're going to run it with the battery pulled out you'll need to use a 2.4A charger. The one included with the MR1100 isn't suitable for running it with the battery removed.
Whilst it's not intended to run a mobile hotspot 24/7 you can give that a try.
gflynt
Thanks
