gflynt
Dec 27, 2017Aspirant
Can I leave plugged in and on all the time??
ok, I read through a LOT of post and cannot seem to get a consensus on this. I've tried others brand like Franklin but usually quits in two or three days. Tried everything including taking out batte...
UK-based
Dec 30, 2017Luminary
I've been running my MR1100 for a couple of weeks now, with an upgraded charger and no battery. It's also connected to a Gigabit Ethernet switch via the Ethernet port and I've got 2 additional access points connected into the switch to distribute dual band WiFi around the house (the WiFi signal strength from the MR1100 understandably isn't as strong as a larger device). Please see this earlier post I wrote (message 12) explaining about my upgraded charger and ways of reducing the MR1100 temperature: Nighthawk-M1-Drops-Internet-Overnight-why
ACTUAL
Jan 02, 2018Aspirant
Not sure this is my issue exactly, my unit just seems to "go to sleep". My wife starts work before me and she notices no internet connectivity is associated with an AMBER LED on the device, a light press of the power button and about 20 seconds later, the LED is Blue and internet restored......can NETGEAR please provide an always on or keep alive mode.
- UK-basedJan 02, 2018Luminary
According to one of the Netgear moderators, there will be a new firmware release in Feb that will allow the Ethernet port to be set permanently on (no timeout as at present). Also the Ethernet port will be able to be switched on by default after a reboot, instead of off by default, as it is at the moment. See this post for more details: Nighthawk-M1-Ethernet-Port-Timeout
- gflyntJan 09, 2018Aspirant
Just ordered a unit from Att call wireless internet. They refer to it as the Nighthawk and they also state it can be powered all the time. We will see when it arrives. I'm attaching a picture.
- UK-basedJan 10, 2018Luminary
When the unit arrives, check the amperage printed on the mains charger. If it's a 2A charger, which is what Netgear have been supplying up to now, it's unlikely you will be able to use this to run the M1 (MR1100) without the battery installed. It will keep rebooting, generally when some sort of activity occurs. Here's what I did: Nighthawk-M1-Drops-Internet-Overnight-why
