drcar
Jun 27, 2017Tutor
Can I locate the position of the AC810S on 'Find my iphone' ?
I am thinking of installing Netgear AC810S on my caravan with Telstra 4G SIM card. Can I locate the position of the caravan on the "Find my iphone" ? if it is working, I would rather b...
- Jun 29, 2017
Hello drcar
If you would have a apple device on the caravan then it should work if the aircard keeps a connection.
DarrenM
DarrenM
Jun 29, 2017Sr. NETGEAR Moderator
Hello drcar
DarrenM
- drcarJul 05, 2017Tutor
Does it mean AC810S itself can not be used as GPS Tracker?
Can We check the location of the AC810S from a Windows PC or from a smart Phone?
- drcarJul 26, 2017Tutor
I used old iphone 4 without SIM.
it is working and the iphone is also working except making a normal phone call,
SMS is working, internet is working. everything else is working.
Excellent idea.
