drcar
Jun 27, 2017Tutor
Can I locate the position of the AC810S on 'Find my iphone' ?
I am thinking of installing Netgear AC810S on my caravan with Telstra 4G SIM card. Can I locate the position of the caravan on the "Find my iphone" ? if it is working, I would rather b...
- Jun 29, 2017
Hello drcar
If you would have a apple device on the caravan then it should work if the aircard keeps a connection.
DarrenM
DarrenM
Jun 29, 2017Sr. NETGEAR Moderator
Hello drcar
DarrenM
drcar
Jul 05, 2017Tutor
Does it mean AC810S itself can not be used as GPS Tracker?
Can We check the location of the AC810S from a Windows PC or from a smart Phone?
