drcar's avatar
drcar
Tutor
Jun 27, 2017
Can I locate the position of the AC810S on 'Find my iphone' ?
  I am thinking of installing   Netgear  AC810S     on my caravan with Telstra 4G SIM card.    Can I locate the position of the caravan on the "Find my iphone" ? if it is working, I would rather b...
  • DarrenM's avatar
    Jun 29, 2017
    Hello drcar
    If you would have a apple device on the caravan then it should work if the aircard keeps a connection.
    DarrenM
