hummous's avatar
hummous
Guide
Nov 12, 2022
Can I unlock the AT&T M6 Pro hotspot and use with T-Mobile?
thx
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    You can ask AT&T for the unlock code. But it is not recommended since AT&T M6 doesn't support T-Mobile bands. You can try our retail SKU MR6150-100NAS. It has both AT&T and T-Mobile band supports and it is unlocked.
    Thanks
    • hummous's avatar
      hummous
      Guide
      Hi, thanks for the reply. What are the T-Mobile bands? I'm just confused since the iPhone 14 has the same Qualcomm X65 modem, and it has all T-Mobile, AT&T, and Verizon bands.
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        On AT&T M6, we didn't enable T-Mo bands. Also AT&T and T-Mo have different CA, EN-DC support as well. If they are not set based on the network capability, the device performance will be significantly impacted.
        Thanks
