hummous
Nov 12, 2022Guide
Can I unlock the AT&T M6 Pro hotspot and use with T-Mobile?
thx
adamjj
Mar 13, 2023Initiate
JohnPeng John, can you advise the correct sim card? The sim cards are the ones that came inside of the MR6500 when purchased on the Business Wireless Broadband 100mbps 5G plan. Is there a specific SKU or sim model number for AT&T? I have their advanced tech support team on the line, and they are advising that the sim card 6531C should work, but they are still unsure.
JohnPeng
Mar 13, 2023NETGEAR Expert
Just checked internally, 6531C should work. But it also depends what plan will be activated by AT&T. Please make sure activate a plan with 5G support and use nrbroadband as APN name. broadband APN is for LTE service as we know.
Thanks
John
