eastonw
Jun 24, 2017Follower
Can I use LB1120 on a GSM network?
I have a couple of solar power installations in Haiti. I would like to monitor them over the internet. Can I use this device on the Digicel or Natcom network? I believe both networks are GSM. I w...
DarrenM
Jun 26, 2017Sr. NETGEAR Moderator
If the provider uses these bands then you should be fine
LTE Category 4
Bands 2, 4, 5, and 12
3G UMTS
Bands 2 and 5
2G GSM LB1120-100NAS
Not supported
DarrenM
