MrChang
Mar 31, 2022Aspirant
Can I use M1 as a modem for a X6 R80000
Does anyone know if I can use my Nighthawk M1 as a modem and connect it to a Nighthawk X6 R8000? It will serve as a moore powerful router.
Mar 31, 2022Guru - Experienced User
yes you can.
To prevent a double nat though you'd either want the m1 in passthrough mode or the r8000 in access point mode.
